How to build a SHAPED guitar hardcase? http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=50528 |
Author: | LPBR [ Tue Apr 17, 2018 12:35 pm ] |
Post subject: | How to build a SHAPED guitar hardcase? |
Hey friends! I am not sure if this is the right place to start this thread but here we go... I think this may be a bit tricky because I searched online and found absolutely NOTHING about the subject! OK, I am after some advice on how to start building SHAPED hardcases for my guitars. I know how to make rectangle cases (actually I have made some) but I find them very ugly and clumsy and now I would like to try to make shaped ones. Any clue about which direction to go to start making my shaped cases? I would appreciate tips, material reference, etc... Thank you! |
Author: | B. Howard [ Wed Apr 18, 2018 6:10 am ] |
Post subject: | Re: How to build a SHAPED guitar hardcase? |
You need bending plywood. This what I used to by when I ran a cabinet shop, pretty sure they use similar to build cases. https://www.columbiaforestproducts.com/ ... g-plywood/ |
Author: | LPBR [ Wed Apr 18, 2018 7:09 am ] |
B. Howard wrote: You need bending plywood. This what I used to by when I ran a cabinet shop, pretty sure they use similar to build cases. https://www.columbiaforestproducts.com/ ... g-plywood/ Thank you for the heads up! Yesterday making some research I bumped to a very nice material that I never had seen available for consumer before (in my country at least, Brasil)... flexible plywood. It turns the shaped hard shell making into a whole different story! ![]() |
Author: | johnparchem [ Wed Apr 18, 2018 10:50 am ] |
Here is a presentation by Ralph Nord on the Seattle Luthiers Group site. It has details of the materials and the process of making it. Lots of pictures. http://seattleluthiers.org/wp-content/uploads/2017/01/Form-Fit-Guitar-Case-Construction.pdf |
Author: | LPBR [ Wed Apr 18, 2018 11:48 am ] |
johnparchem wrote: Here is a presentation by Ralph Nord on the Seattle Luthiers Group site. It has details of the materials and the process of making it. Lots of pictures. http://seattleluthiers.org/wp-content/uploads/2017/01/Form-Fit-Guitar-Case-Construction.pdf Wohay! Thank you John, I will take a thorough look on this documentation! This is no doubt one of the more valuable publication I have had the chance to put my hands on! ![]() |
Author: | profchris [ Wed Apr 18, 2018 12:20 pm ] |
Or you can bend ordinary plywood on a hot pipe - I've made a few cases that way. But nothing thicker than about 3mm/0.125 inches. Plywood can be a little tricky to bend, as a void or weak spot bends differently from the rest, but it's not too hard to do. Worth an experiment if you have a few scraps of thin enough ply and a hot pipe. |
Author: | Mike_P [ Wed Apr 18, 2018 5:33 pm ] |
http://fraulini.blogspot.com/2016_03_01_archive.html |
